slippery when wet
mel
10 Jan 2006
NR GRIMSBY
patio decking
its been treated in some form of cuprinol paint {forest green}
but it doesnt need to be very wet to be extremely slippy
so , what do you all suggest
thanks byron
ive got a long thin strip of carpet . barrier matting , to be precise
but as soon as you step off of it :shock:
i was looking for a more permanant solution
mel and john":3axkk56g said:
patio decking
Repaint with the same, but when its still wet, throw a few hadfuls of dry sand on it, to create some "grip". Alternatively, as odd as it sounds, I found we got an green algae on ours, and pressure washing it worked wonders to make it less greasy.
Adam
scrit
how i wish
adam
i think that pressure washing the decking was the start of my problems
ill ring cuprinol today to find out what they say about it
Its most likely algae as Adam says and pressure washing is the way ahead. If its the grooved kind, its even more likely to have algae probs.
Tim
Not pretty, but light gauge galvanized wire netting stapled to surface works from a HSE point of view.
Wot about vim and a scrubbing brush and a gentle rinse? I take it yours is got the grooved surface?
Pressuire washers are fast and seem easy but they will also tend to rip the top surface of the wood away making it raggy and so on which will tend to keep the wood wetter for longer. Perhaps use a weak water/bleach solution to deter more alga slime from growing?
Just a thought Jonathan :D
