transatlantic
Boom!
I've just purchased a Record RSBG8, and a few things occurred to me.
1. Why do standard bench grinders run at such a high rpm? surely you only need that kind of speed if you're removing a lot of material? ... in which case, wouldn't you just use a lower grit?
2. Why aren't variable speed bench grinders a standard thing? I'm know they cost a little more, but wouldn't being able to run at a lower rpm be safer, cooler and most of all, extend the tools life as you're not removing as much material?
3. Why do most turners use grinders instead of waterstones/diamond stones etc? ... I've seen a few people use stones for skews, but that is about it.
