This topic might be of help to anyone struggling to set their planer knives to the same height.
I thought having them all the same height was crucial to getting a good result.
" I tried one last time earlier today. I lowered the outfeed table so could get the ruler to move by 4mm.
Knife three moves the ruler by 4mm, knife two by 6mm and knife one by 2mm. I didn't bother to check the movement at the other end of the block as would have had the same inconsistent results. "
Axminster engineer replied,
" The difference in height of the blades is amplified in the distance the straight edge moves across the bed.
I mentioned in my previous email the scale you are working to (0.10mm is roughly 5mm of travel) therefore;
1mm of travel on the straight edge is about 0.02mm so the height above the outfeed table you have is around 0.04, 0.08 and 0.12mm. This will work fine, the material will grow or shrink a lot more than that depending on the weather.
Setting the machine this precisely is a bit like setting your car tyres so the O of Goodyear lines up with the valve for balancing purposes, not necessary. "
So, there you go
So, there you go
