I've actually been thinking about this very recently for my own machine. I'm not sure whether a full-size 0-13mm chuck would fit in the opening but I haven't properly measured it. If I remember off the top of my head the standard collet holder is 35-40mm or so in diameter and there's perhaps 10mm of clearance between that and the casting.
Then, even if a chuck could fit, you'd need to either thread or put a taper onto the motor shaft to hold it which involves stripping the motor down to get the rotor out and having it professionally done unless you can do it yourself. Alternatively, you can get
ER20 collet holders which hold up to 13mm rods that will fit on a motor shaft but I think the largest bore you can get is 16mm, so you'd need to have it bored out to 19mm or 3/4", whichever it is.
In all, there's no real easy way to do it from what I can see.
