B. Reynolds
Hi there, not posted before so hope this works.
I'm after some advice on my planer, its an old Sedgwick MB (with the shorter tables and a 2 knife block)
I'd really like to know how others with this machine go about getting at the grub screws in the cutter block. My old machine had wedges and bolts that, when wound out, held the knife in the block. The cutter on the Sedgwick has allen grubscrews which, when tightened, pin the clamping plate against the knife, holding the knife in the block. The slot in the sedgwick block is parallel as opposed to wedge shaped like my old machine. I imagine this is due to the age of the machine and modern safety regs insisting on a safer design. I appreciate a photo would be handy but I'm not with the machine at the moment. I'll take some tomorrow and try and post one or two.
The only way I can see of getting to the grubscrews is between the top of the outfeed roller and the bottom of the infeed table using a very long allen key! Seems crazy.
Hope I'm just being daft.
Any info would be greatly appreciated.
Cheers Ben
Cheers Ben
