Sealey SM12 Bandsaw
A
Anonymous
Guest
I have just become the owner of a second hand SM12 :D
However I seem to have a bit of a problem :-({|=
I have no instructions and can't talk to the previous owner, when I try a do a cut it wanders off to the left as I look at it. There are guides for the blade above and below the table but I don't know if they are set right. It came with 3 brand new blades but the one in it seems sharp to me.
Any advice will be very welcome
Grumf
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Grumf
It sounds to me as though the blade has been used for cutting circles.
I think if you change it for a new one, preferably a Dure Edge blade, your problem will be solved.
Neil
devonwoody
11 Apr 2004
Paignton Devon
Grumf.
You have a learning curve coming as regards setting up the bandsaw.
First; Release all bearings, and that blade runs on tyres centrally.
Second; Make sure the table and blade are correctly set SQUARE
Third; Set lower bearings, use a piece of paper between all bearings and the blade
Fourth Do the same with the top bearings.
Then do a test on a SCRAP PIECE OF TIMBER.
If still has a wander you most probably need to set the fence angle to correct path of timber past blade.
I now love my bandsaw.
A
Anonymous
Guest
:eek:ccasion5:
Thanks for advice, unfortunately I work away and so will have to wait until I get back to put it all to good use.
Grumf
