Random Orbital Bob":1gxy8m9w said:
I have to be honest, for fine furniture work I still use my yankee drivers, different sizes for different jobs because then I'm in touch with the torque of the screw and I know when it feels just right. Any form of powered driver technology cuts you off from that feeling though for speed the torque clutches can help of course.
That simply isn't true. It's just a different technique. As someone who owns a Yankee, I know they're not idiot-proof either - you have to feel your way with both, but both work well.
Many years ago, I had to stop using manual screwdrivers (for most things), after stupidly starting to repair a boarded floor by hand, using 'twinquick' screws. Tennis elbow was the result, and it was really painful. A year or two later arthritis sealed the deal, and now manual screwdrivers are for special circumstances only, most often when re-assembling plastic home electronics (where you really need precise feel or it's game over). Even there, I dismantle using an electric driver, as it's faster and better for both screws and plastics.
One has to learn to use electric properly, and adjustable clutches are good, but you don't really need them (my first cordless drill didn't have any sort of clutch) you do need reliable varispeed though.
Although I have one and like it a lot, electric 'rattle guns' (impact drivers) only have very limited use in woody applications, made worse by modern screws (self countersinking screws and rattle guns do NOT go well together!).
The big difficulty is that you need to feel the point where the screw finally pulls up into the stock. A rattle gun drives too well, especially with any type of good driving bit fitted. Unless you use a lot of care in softwood, it's one or two thumps of the gun between a screw not driven home and one that's punched below the surface nastily. I think that's in no small part down to screw design, and having no subtlety in the 'thumper' mechanics of the driver.
As for mangled screw heads afterwards, obviously it's poor technique. In my experience, a screw properly driven by an impact driver usually has less damage than one from a non-impact electric tool, assuming the use of a good quality engagement system (the screw head and bit type). If the head is already damaged though, an impact driver can make matters a lot worse very fast.
That said, for me an electric driver will remove screws that can't be shifted any other way. I think that's because I can concentrate on keeping it straight and the amount of force I'm applying. I rarely attempt to shift anything stubborn with an impact driver, as I've had too many failures in the past. The old 'thump the back' manual ones are OK, but not the electric ones.
E.
