transatlantic
Boom!
So I had this idea that I wanted to try ....
You're often in the scenario where you're cutting with a hand saw, and to check you're cutting at a consistent depth at both ends of the cut (such as cutting the cheek of a tenon), you have to keep stopping to look around the other side to make sure you haven't cut past the line.
Wouldn't it be super useful if saws had lines along the blade that are parallel with the teeth, enabling you to easily see if you're cutting at a consistent depth?
Question is, what would be the best way to mark the metal so it won't just rub off? My japanese saws I believe are some kind of stainless steel. I think laser engraving would be ideal, but I don't have acess to one
![Untitled.png Untitled.png](https://cdn.imagearchive.com/ukworkshop/data/attach/62/62453-Untitled.png)
