jamesmerrix
Hello,
I have a problem with the drive belt on my planer.
The belt that takes power from the end of the cutter head and transfers it down to the thicknesser gears seems to be out of alignment, and keeps trying to 'climb' off its lower pulley.
The only thing that prevents the belt from coming off completley is the second belt that is also used to drive the thicknesser gears.
Hopefully the pictures below should illustrate the problem.
I cannot see any adjustments that could be made, but clearly something is not running true. One way that might solve the problem is to remove the nut and washer from the end of the cutter head (which serves as the top pulley) and add another washer to the shaft to keep the belt from moving too much. while this might work, i am reluctant to start messing around with it, as it should be ok on its own.
Has this happened to anyone else here?
does anyone have any ideas.
many thanks
james
many thanks
james
