OK here is a series of pictures that should provide sufficient info. The whole thing is extremely basic, even while I was photographing it I spotted a good modification, more on that later.
First off then is a front end view showing the timber dimensions, the other dimensions really don't matter, you can make this to whatever scale you like.
This is an Oblique view showing the carrier for the sash clamp, again, as Dalboy indicated, you could substitute any number of methods to steady the timber.
The improvement involves attaching the two log carrying 2X2 lengths to a third length of 2X2 at the front with the screws going in from below, then attaching this to the back of the 3X2 cross member, this would prevent any risk of hitting screw heads with the saw.
This view shows the main reason for the design, my garden has a severe slope, hence the legs at the front, but low at the rear. However, you could easily adapt the design to suit circumstances or preferences.
The two carrier sections of 2X2 are adjustable for width by means of a single screw in each into the 8X2 rear plate.
This is a detailed view of the sash clamp holder, the clamp is held by a 6" nail or similar.
A front end view with the sash clamp in place holding down a log.
