Quantcast
Sagging router insert plate
Routermonster
10 Aug 2006
Worcestershire, England
Hi All
I've been using my router table to cut rebates and tenons for my current project (yes, I should be doing this by hand but at the moment I have to take care not to strain myself ! ).
I could not get consistent depths of cut, and I have found out the reason - my insert plate is sagging. It's only by a small amount but it's enough to spoil things. I took it out of the table and removed my Trend T11 router but it's still sagging. I bought it a few years ago from Axminster. It's made by Rousseau (I think it's identical to the one marketed by Trend) , and it's supposed to have a crown of about 0.8 mm.
Has anyone else got any experience of sagging phenolic plates?
I spoke to Axminster's customer services people but they classify this product as obsolete and no longer support it. I checked the manufacturer's website and they claim it has a lifetime warranty! I guess I could contact them but is it worth the effort?
I contacted Woodworker's Workshop and spoke to Roger, who was very helpful. He sells a pre-drilled aluminium plate made by Incra. It's expensive but it's solid and looks bomb-proof.
The problem with most of the current crop of insert plates on offer is that the sizes are different from the Rousseau/Trend plate and the Axminster-branded one. If I buy the Incra plate (or even Jessem or Kreg) I may have to make a Mk 3 router table!
Les
marcros
11 Feb 2011
Leeds
Routermonster":3c1v0m07 said:
Hi All
Les
Could you not have a plate made to size from some auminium- it probably wouldnt be as expensive as you think. I priced one up from a local fabricators, made from 2 sheets of 3mm aluminium, and for a 1off they wanted about £40, including drilling, milling and 3 inserts. That was about 300x200mm IIRC. Even if it was double that, if it saved you having to make a new table, it would be worth doing.
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Yup, i had the Trend one, bought it with a T11, only lasted a few months before the crown, that was definitely there when i fitted it in the table disappeared & turned into a hollow.
IIRC I gave it foc to a forum member, with an explanation of why i was changed to a metal plate. Cant remember where i bought the new plate but it fit nicely in the existing hole.
BTW nice to see you back posting Les.
Cheers.
Eric The Viking
19 Jan 2010
I've got the Axminster aluminium plate with a T11fitted.
I've had it about two years with no issues - the T11 lives in the table.
I'm fairly certain the plate is imperial-sized, though it is 8mm thick. I thought they all were in inches, actually.
Mr Ed
4 Nov 2007
Derbyshire
I've got the same issue with the same router plate. Mine has a DW626 underneath and the weight is evidently just too much. I am planning an upgrade to a lifter type metal plate in due course.
I had the same accuracy issues with tenons and some additonal bracing provided a short term solution, but the sag is soon back.
Ed
chippy1970
3 Jun 2007
London
I have a 626 in one of those plates too. Not really used it fully so cannot comment but after I bought the plate I spotted on here about the sagging lots of people changed to Ali ones.
Harbo
13 Nov 2006
Hampshire
I've got a Woodpecker Phenolic supporting a DW625 - for several years now, with no problems?
They also make an ally one too.
Rod
Dibs-h
23 Jul 2007
West Yorkshire
:lol: Sorry - not doing any more -well this year anyway. Although might be tempted to do another batch of say 10, but only in either steel or aluminium, as I have another order (of something else) for the laser cutters\machine shop.
Anyone interested?
Dibs
studders
23 Mar 2009
Petts Wood, Kent
Anyone interested?
Dibs
You betcha.
Another sufferer from Phenolic Sag.
PS Can I pay you now? That way Santander might just get the payment to you on time, this time. :)
marcros
11 Feb 2011
Leeds
Anyone interested?
Dibs
Yes, I would be interested.
Dibs-h
23 Jul 2007
West Yorkshire
studders":29fi8o49 said:
Anyone interested?
Dibs
You betcha.
Shall we start a new thread in the Jigs & Tips forum?
Dibs
woodbloke
13 Apr 2006
Salisbury, UK
I've noticed a little bit of sag with my phenolic plate and the T11. I'm going to be buiding a new table later on and intend to use the alumimium plate from Axminster which I understand is much better. I'v kept the old one though as I can pick off the dimensions to drill the hole for the T11 'through the table' lifter - Rob
Eric The Viking
19 Jan 2010
I've still got some actual-size drawings somewhere (PDF or Corel Draw to A3 paper), if useful (there are dimensions with the T11 instructions).
From memory, Trend say 20mm for the hole. I used 17.5 or 18mm as it's too close to one lead-on pin hole. That's fine for the handled-socket Trend supply, but too narrow for my 3/8" and 1/2" drive sets, so no "motorised" lift until I've enlarged it slightly :-(
You could rotate the router 180 degrees underneath, but that puts the speed control on the wrong side of the table, so you can't see it, and the fence will block access to the lifter bolt head. I should've tried just twisting the router a bit: that would be the best solution.
(homer) D'oh!
E.
