Monkey Mark
Hi all,
I remember some time ago seeing a kit that had guides in 1/32 increments for making over-sized or undersized flush cuts. What i mean is rather than having a standard flush cut you could adjust the cut so as to have, just as an example, two templates the same shape but a 32nd or 16th or whatever different in size. If this doesn't make sense, check this video as he uses a set in this. https://www.youtube.com/watch?v=RBwzXQEjJyU
The kit I saw was very over priced.
Any idea if something like this is available (other than the silly priced one in the video)? I have used a wrap of tape on a bearing to over size in the past but can't think of an easy way to under size other than buying a whole load of different bearings.
