woodfarmer
Today I was machining more stainless steel (en316) on the Holbrook using HSS tooling. Even now after 90 years of abuse it will still repeat to 2/10th's of a thou. with a sharp tool, it will cut to a size, run the tool again at same number and it just squeaks, add 1/5 of a thou to the wheel and a thin sliver peals off. and you can continue to take those 1/5's of a graduation off one by one.
I am so pleased I rescued it from being scrapped back in 1970. I fixed the original fault it had then and the reason for its removal from a machine shop. and since my little refurbishment last autumn have discovered another botch up from those days. It is getting better but I doubt it will ever look new again.
They definitely don't make them like they used to.
