I want to replace a pair of corbels for a porch (which were at one stage removed), they are they shaped pieces with the 3 holes that fit between the vertical and horizontal frame
see pic of neighbours
The overall size is of corbel is 215 mm wide x 285 mm long x 45mm thick
The question is should I make them out of:-
1. softwood 225 x 50 nom planed - I'm a bit concerned about movement/splitting etc. when screwed to the vertical timber and horizontal frame
2. or glue 3 layers ply together ie. 18 mm x 2 plus a 12mm piece
I think that the ply route is the safest as far as movement is concerned.
Any thoughts?
the vertical timber fixed to the wall is also missing so will have to be replaced
Any thoughts?
