- Joined
- 11 Mar 2009
- Messages
- 1,315
- Reaction score
- 11
Hi,
I posted about our boiler woes 2 years back and have only just decided I need to sort it out. Given the problem only happens when we turn the central heating on I am putting my money on the problem being the internal expansion vessel.
Now what I want to know is whether I can fit an external vessel to the system and somehow isolate the internal vessel so that it is not used by the boiler.
The reason I think it is the expansion vessel is that when the central heating comes on the boiler starts heating up a greater volume of water than it does when just in hot water heating mode. This greater volume then results in a great expanded mass when hot compared to when in just hot water mode.
Whilst my theory might hold true, what I still don't understand is where the water in the sealed system is going as I don't see water pouring out of the pressure relief pipe on the outside of the house.
Now, if my plumbing knowledge is correct, water can only leave a sealed system in 4 ways
1. Through the pressure relief pipe on the outside of the house. Would see dripping if the pressure in system > pressure relief valve setting
2. Cracked heat exchanger causing water to leak out
3. Leaking joint or rad valve
4. Perforated coil in hot water tank. This would affect hot water mode so this can be ruled out
Have I missed anything off here?
A right royal pain as we have sold the house and I cannot afford to have the now obsolete boiler replaced.
