Record Disc sander
Claud1
16 Jan 2012
Aberdeenshire
I bought a brand new Record disc sander about 8 months ago, cleaned the grease off the disc with white spirit and dried it with a clean cloth but the discs won't stay attached. Can anyone advise me as to what I may be doing wrong. I also bought the Record discs for the sander.
okeydokey
21 Nov 2014
Burgess Hill UK
White spirit is the problem, its quite good at removing sticky labels from things so may leave a residue on the disk.
I would thoroughly clean with meths using not the white spirit cloth and give a final wipe over with a fresh cloth/kitchen paper towel with meths then let air dry. Then use a fresh sanding disk (not one you have tried before) and all should be well
Blackswanwood
Still Learning
17 Nov 2018
North Yorkshire
Previous post may be right but I’d have said it sounds like a problem with the adhesive on the discs. I have one but use Hermes self adhesive discs from Axminster and they stick ok and I clean the face of the metal disc with white spirit when I change them.
Lazurus
22 Sep 2017
Norfolk Broads
As above I use acetone to clean the residue then fit the Axminster disk my backplate is melamine faced ply
Sheptonphil
Scrumpy junkie
29 Dec 2012
Somerset
I have the record 0” disk sander, the discs when they do stick are a real pain to change over. They leave so much residue on the disc you spend longer cleaning the disc than sanding. Far better is to get a 10” hook and loop disk off eBay, stick that to the sander plate and then use hook and loop sanding discs.
whatknot
29 Jul 2017
Cornwall UK
When I looked around a few years back for a 10" velcro type backing for my sander I couldn't find anything wider than 2", so used that in strips across the disc, its still holding fine after many changes of sanding disc
Sean Hellman
27 Dec 2009
South Dartmoor, Devon
They sell precut velcro and sanding discs, almost any size, too must hassle to do a DIY.
Also never had a problem with sticking and always used white spirit.
whatknot
29 Jul 2017
Cornwall UK
Do you have a link or supplier for the precut velcro as I couldn't find any a few years back or now
