Record 25 vice casting repair
Solverson
10 Dec 2019
Edinburgh
I recently picked an Irwin Record 25 vice out of a scrap bin at work. It was thrown there having “given out” whilst clamping a heavy casting that was having its bolts torqued to ~400Nm. Each time it slipped in the jaws, they gave the vice handle a hammering to tighten it further. As a result, the casting that braces against the half-nut has broken. The quick release mechanism had also been pulled over to one side and no longer engaged the screw. The vice was binned without any further investigation.
Having rebuilt the vice, it all works fine but the half nut is now only half supported so I want to repair the damaged casting. The image below show the underside of the vice quick release mechanism
The next image is looking to the vice with he front jaw removed – showing the broken part of the casting
The final image shows roughly where the half nut sits when it is engaged.
According to the Irwin Record website, this vice is made from ductile iron. However, I am unsure how to proceed having never repaired cast iron before.
My thoughts are that I could get the broken part of the casting brazed back on as I still have it, but I am unsure how easy or how strong that repair would be. The second option would be build the area back up by welding it then grind it back into shape – again, I am unsure how easy this would be or how likely it would be to cause failure due to creating a heat affected zone around the weld. There are probably also other ways to repair this that I haven’t considered.
I’m guessing there will be guys on this forum that have experience of similar repairs and I would appreciate any advice I can get.
Thanks in advance :)
RichardG
If at first you don’t succeed have a cup of tea.
29 Mar 2018
South Norfolk
You could think about cutting off the other wing and then grinding to make a flat platform. Fabricate a new part from a steel block (hacksaw and file) and then drill and tap the casting to fit.
Gordon Tarling
25 Apr 2021
S. Lincs
I'm fairly sure that the right person with the right knowledge would be able to braze or weld that part back on. Finding that right person might be a bit more of a challenge! In order to effect the repair, both parts will have to be heated to near red heat, the welding/brazing carried out and then the part cooled slowly. You might find more info about this sort of repair on the model engineering forum.
G.
Solverson
10 Dec 2019
Edinburgh
Thank you for your advice - I hadn't really considered fabricating a replacement part but I think I'll have a go at making something and see how it looks.
Solverson
10 Dec 2019
Edinburgh
G.
I had a look online and I think I have found a small copany that claims to be able to braze or weld anything - including castings. I think I'll visit them in the next week or so and get their opinion on it. As RichardG suggested - it might also be an idea to make a replacement part out of steel. It may even make sense to make a new part then get it brazed on. I'll let you know how I get on.
Thank you for your input.
