Raised panels
guineafowl21
28 Oct 2015
Inverness
I did ask this as part of my kitchen sideboard project thread, but it probably deserves its own.
I hand-planed some raised panels for standard doors, and had trouble getting the raisings even. Does everyone do them on a table saw?
Where the panel fits into the 1/4” groove, it’s sloped. Should I make the edge width less than 1/4”, rebate the edge, or chamfer the groove?
I do mine using router sled on a home made tilt jig. I just cut the slot for fitting the panels so it will be snug and don't worry about the slope. However, I just do this for my own stuff and have never researched if there is a "proper" way to do it.
Thanks for the replies. I do have a hand-held plunge router, so perhaps a bit for that is the way to go.
It will only ever be a few panels for a specific project, hence why I did them with the no.4 plane. They ended up with a nice convex curve, and all I did was draw a depth line slightly under 1/4” and shot for that. Then I took a stile or rail with the groove and tapped it onto the panel, took it off and planed away the bruising until it all fitted.
I am not even remotely qualified, but I have just made some raised panels on the table saw, and was very pleased with the result. The reason I don't want to use a router is that my router doesn't have variable speed, so I can't put huge bits on it.
So, I cut the raised edge at an angle of 12°, and set the blade to almost emerge from the face of the panel - this gives you a square edge around the inner portion of the panel (is there a name for that?) as another shadow line (I may be pontificating about things I don't fully understand). I then square up the edge so it fits neatly into the rebate. It's gone rather well, which for an agricultural wood butcher like me is astonishing.
Attempting it with a hand plane would be far beyond my humble (lack of) skills.
To make a raised panel (including the parallel section that slots into the groove) accurately with hand tools, so that it looks half respectable is actually quite difficult. I've done it once or twice and don't want to repeat the process but conversely, it's dead easy in a router table - Rob
