Quick question on oil stones
dm65
27 Dec 2012
Leeds, West Yorkshire
Just been using an oil stone for the first time in many moons and as its new, any oil I put on soaks straight in - should these be charged in some way like water stones or do I need to use something thicker like engine oil ? (I do have some and will use it as the bottle I got with the stone is now half full or empty depending on how you swing)
Have managed to get a lovely edge on one of my plane blades though after watching a Paul Sellars youtube vid last night
3 in 1 is my usual for an oil stone. There should be a pool of oil on the surface to help the metal debris wash away. If it gets impregnated with metal I use WD40 and a piece of kitchen roll in a squirt-dab-squirt-dab process. The WD lifts the metal out of the stone and the tissue soaks it up before it has time to sink back in.
I would keep loading it with oil until you get a pool on the surface.
Just squirt it on until it pools as grayorm says.
I keep em clean with a magnet. Also occasionally freshen the surface with a 3m diapad or something similar
Thanks Grayorm
It didn't seem right the way the oil soaked straight up but I wondered if some sort of capillary action brought it back up
And I had to keep adding oil as I soon got to hear the difference between dry and wet
