redmoorphil
Hi guys,
I finally got around to ordering my hegner quick clamp following the recommendation of just about everybody who has one.
I also ordered the quick lever to replace the hegner knob weeks ago when i ordered some blades from Mike.
Now that I have gone to put the two together I just wanted to raise an issue with the lever.
The Hegner quick clamp comes with an internal bearing which still allows the blade to pivot properly even when the clamp is tightened into its holder. Hegner recommend that the blade holder is tightened firmly into position when using the quick clamp rather than loosening the clamp screw a little as you do with the normal blade holders.
If, however, you fit the lever then it has no bearing fitted. It is just a threaded rod which clamps the blade into the holder.
The problem I see with this is that the blade wont pivot properly unless the blade holder is set a little loose so it will still pivot. If it is set loose then tightening the lever bends the blade, so you have to tighten the top screw before using the lever and then loosen the top screw again when you are done
I would be interested to know how others get around this or if it is not actually an issue as I don't want to fit my lever if it causes as many problems as it solves.
Many thanks,
Phil.
Many thanks,
Phil.
