Question on order for tapping thread
smckerrell
12 Jan 2022
Scotland
Hi all
Newbie here, thank you for adding me.
I’ve just bought and had delivered three M4 taps to make a thread in some mild steel—the three are supposed to be used in order—is there an easy way for me to tell which one to use first, second and third please?
The only difference I can visually see is a slight difference in each in where the thread begins proper—so hoping that might be useful?
All help much appreciated
Simon
Bod
18 Nov 2013
Wiltshire.
1st tap has least threads, and most taper.
2nd tap has small amount of taper.
3rd tap has no taper, and full threads.
If the metal is not too thick the maybe only the first two are needed.
The third is for threading blind holes almost to the bottom.
Bod
redhunter350
17 May 2018
North Lancashire
Simon, Bod is correct but just do you know there are also sets of “serial” taps. These ere much the same except the taper and second taps are a smaller diameter thus cutting progressively deeper threads and the third or plug tap must be used for the final thread. Don’t forget to use a suitable cutting lubricant !
Dalboy
18 Sep 2008
Canterbury United Kingdom
Also to add to the order of the taps and most important is drilling the correct hole for the size of tap and keeping it square to the hole otherwise it may become harder to tap the deeper you go. Normally ends up breaking a top. Turn tape 1/4 turn in then reverse to start with as a beginner
hawkeyefxr
23 Jan 2017
hants
As a rule of thumb only turn the tap about a quarter of a turn when cutting the thread, you then back it off anticlockwise then carry on. If it feels sticky reduce this to an eight of a turn and back off.
chaoticbob
14 Nov 2012
Wirksworth
The OP has probably tapped his holes by now, but assuming the taps in his set are standard ISO 529 taper, 2nd and bottoming rather than the serial taps John describes, it might be worth saying that there is no requirement to use the taps in order. The only difference between them is the chamfered lead - typically 1-2 threads for bottoming, 3-5 for 2nd and 7-10 for taper. If you have a way (eg drill press or lathe) of holding the tap square to the work it's perfectly OK to use a bottoming tap from the outset - I have threaded several hundreds of holes both through and blind this way. The only use I have found for taper and 2nd taps is when tapping freehand where it's next to impossible to start a thread true with a bottoming tap.
Serial taps can be identified by the bands on the shank - one band for the first, two for the second and none for the third.
Bob.
John Hall
19 Jan 2022
Manchester
And when using small sized taps like this, it’s really easy to snap them if tooooo much pressure us used, gently does it, don’t try and force them round especially in hard steel etc. It is better to start with the first/ taper tap as this will start cutting without much force and enlarge the thread gradually…Make sure you use the correct tapping drill, and try and buy good quality taps and dies like Presto, Dormer, Goliath etc…and use cutting/tapping fluid..
