Outside but the sizes are nominal not exact. measure the pipe under your kitchen sink to check. there is a slight difference also between push fit and solvent weld pipe.
You can also get 50mm and of course 65mm rainwater downcomers are useful as well as 110 soil pipes
Note: To make the connection to the machine, I'd try using a universal connector, which is a compression fitting that will make a good seal when tightened.
