swagman
Attached are some Pull Tooth Kerfing Saws I am working on. The handle wood is Bubinga, 0.020 saw plate gauge, the toothed length will be 120mm, and the hang angle 45* to the tooth line.
The handle has only had 2 coat of Garnet Shellac. I am looking at filing the saw teeth 15tpi; 8* rake; with crosscut fleam.
These 2 Kerfing Saws are designed for cutting out the shallow wedge abutments on wooden bench planes, so no tooth set will be applied. Their design could be easily modified to suit deeper kerfing work where some set would be a requirement.
Stewie;
Stewie;
