Protection for painted emulsioned doors
phil p
29 Feb 2008
Hi,
Just after a bit of advice.
Just made some doors for units, only for the garage and nothing fancy, and painted them with some old emulsion I had lying around and come up quite good, however I was wondering if I could coat them with something just to harden the finish, also to stop moisture in the winter as it's an external garage.
Would a coat of clear varnish be O.K. as I have a few old odd tins lying around?
Phil
I suppose its the equivalent of applying a scumble glaze, I dont see why a standard clear varnish wont work as well as a product specific scumble. Perhaps the usual 'try a small test area first' precaution might be wise.......
Ive clear varnished painted floorboards before and that works well.
I wouldn't recommend a interior varnish be applied outside. It's very likely to crack , blister and flake off causing quite a mess.
Unfortunately I can't think of anything that would sit well on an emulsion paint externally.
How about a coat of Zinsser BIN - which is a shellac based paint. It will go on anything and act as a buffer between 'anything' and whatever you want to put on next.
I think it would be fine - though 'varnish' can mean so many different things. Alternatively use any left over gloss paint or a few more coats of the same emulsion.
The OP did say "units for the garage" - I presume they're indoors?
