johnelliott
I think I might have worn it out! It just won't cut a straight line anymore. I noticed a couple of weeks ago that it was still occasionally trimming bits of rubber off the edge of the saw guide, and the blade is definitely wandering slightly at the end of a cut, and now the cut isn't even in a straight line.
There's a little bit of play on the blade radially, the drive nut (not tightenable) is a little loose on the motor shaft, but I can't feel any side play
I'm on my fourth blade, BTW. I have no idea how many 8x4 sheets I've sliced into 70mm strips with it, and I use it for lots of other cutting tasks, so it might simply be worn out.
It is, however, guaranteed for 3 years, so I shall be going to my local service agents tomorrow to get it sorted out
Would I get another? You bet I would. In fact, if they can't fix it right away then I will be buying a new one to keep me going til this one is fixed
