tekno.mage
I know, I know, I should have bought the Carroll sanding drums, but I was tempted by the 4 drum Axminster set when they were on special offer at around half the price of one Carroll drums. And I then put them away with no real use for them until now....
When I need to use them in anger and have 48 large curved shapes in 30mm thick pine that need sanding :-( All went well to start with - and then I needed to change the paper on the drum. What a mare! Hard enough to get the worn paper off, but I've found it well nigh impossible to get the new sheet on as tight as the original sheet was fitted - so now the paper is too loose around the drum, and I'm thinking this means it will crease and wear faster.
Any tips as to the best way to do this? Do I need a pricey upgrade to the Carroll system?
Also, the paper that comes supplied in the kit is fairly serious cloth-backed abrasive and seems to last reasonably well. What do other people use when the paper in the kit runs out? I've only got abranet (and the pieces are too short to go around the drum) or expensive velcro-backed abrasives I use for power sanding on the lathe (too thick and way too pricey.) Recommendations for an alternative cloth-backed abrasive 75mm wide please?
