Problem with Lurem T30n spindle moulder
toolsntat
Yep, I collect tools and tat
8 Dec 2007
Leicestershire England
This is what mine looks like which is different to the handbook PDF.
Cheers Andy
my one is slightly different, yours looks like it could be a modification. I'm slightly confused why the grub screw us shearing under the key - that looks like upwards thrust to do that or maybe the key is loose in the key way? Is there a key .....it should be a snug fit
Yes the key is a little loose and definitely worn.
As is the fit between motor shaft and pulley hole.
I'm not sure if this is intentional or It is worn.
The tiny size of screw through the key into the shaft makes me think it wasn't original.
The hole in the end of the shaft is threaded as if to hold fast the key in some unknown arrangement.
For anyone unfamiliar with this machine, the motor is designed to be easily removed ie. you lift off the motor bringing the keyway key with it but not the pulley. There is no access to the bottom side of the pulley so unless the key is fixed it can drop through. All online documentation I have found shows a different set up to mine.
This set up means no side load is incurred on the motor itself.
Cheers Andy
I did notice the thread in the motor shaft. Perhaps this bolt was lost or broken and somebody has drilled a grub screw like you said.
Depending on the rotation of the motor I guess that will determine whether it's a female/thread. I ve never seen a grub screw through the key, just drill and tap a bigger grub screw the other side and replace the loose key.
