Halo Jones
What is the minimum length than you can safely put through a thicknesser? Is it the distance between the infeed and outfeed roller?
Reason I am asking is that I am machining some reclaimed wooden flooring, converting it to block work. I would like to cut it all to size (45 x 180 mm) then let it climatise in the house while on holiday then thickness it to final dimension once I get back. I can leave the lengths oversized but would prefer to cut it final dimension so there is less to do when I get back.
H.
H.
