LFS19
I've been getting to grips with the No 5 Stanly that Graham here on the forum sent me.
It cuts excellently, and for the first time since I started woodworking, I've actually managed to use one efficiently.
There are just a couple of issues that I'm running into, and I thought someone might be able to help.
When I'm planing the wood, I get it very close to square on all sides - but that's the point, very close.
I always have just a tiny, tiny dip on one end, or an ever so slight bit of twist or something, and I'm not really sure how to tackle the situations without making it worse.
Take for example, if the entire board is close to perfectly straight and square, but then at the end on one side, (when you have a straight edge on top) some light is showing through.
I'm not sure how to get the dexterity I need to tackle that.
Presumably, it would mean marking the area where the chink of light was and not going over that part, and planing the rest of the board to match the thickness of the low spot.
The problem with this, is its such a slight and precise cut that needs to be made across the board, I usually end up making it worse.
I'm not really sure, considering the point on the board I don't want to go over is so small, how to not got over it when I'm making a pass and bodge the whole thing.
It's the Same with twist, too.
I'll check for twist using my winding sticks, there might be some twist just ever so slightly.
When I've got to plane out this twist, Dispite using a very fine setting, I either make it worse or make not difference at all.
I think it has something to do with where I'm positioning the plane or the blade on the board.
I'm not sure how narrow or thick a shaving I need to take off to elliminate the twist.
Any tips would be much appriciated.
Thanks!
Thanks!
