Dissolve
Hello,
I asked a question a while ago about a similar issue. But I think this is a topic a lot of people will have dealt with previously so I wanted to ask for some advice. I have acquired a Jet JDP 15 pillar drill, it is 2-3 years old but it looks hardly touched, no marks etc. It looks like a fantastic drill, but I am experiencing some noticeable runout/chuck wobble so it needs some set upo/attention before it's a permanent addition to my workshop.
I have removed the chuck/arbor and re-seated them using a firm strike of a mallet, it seemed to help slightly but I can't say it's greatly improved.. To start with, does anyone have some advice on removing dust/build up in the spindle taper? The chuck arbor is smooth/new looking, so I want to check the fit between the arbor and the spindle are perfect.
Assuming I clean out the spindle and this does not sure the problem, I will use a dial gauge and measure the wobble/runout of the spindle itself, there seems to be no obvious indications that a bearing has worn (I'd be very surprised) and there is zero side to side play between the quill/spindle or chuck.
Does anyone have some suggestions on how to find the cause of the runout/wobble and possible fixes? I have no other chucks/arbors to test with it but can anyone tell me how to separate the chuck and arbor to try re-fitting these components?
I might buy a new arbor and try replacing that before anything more expensive.
