Eric The Viking":3ce7otg7 said:
PPS: Keep notes - as a child, my dad encouraged me to keep a log book, recording aperture, shutter speed, etc, for each frame - really handy to understand what I did well, and badly. Some cameras now record some of this stuff, but in my experience often not enough detail.
How much detail do you want!? Here's a full dump of what my (old, launched in Sep 2006) Canon A630 records:
ExifTool Version Number : 9.13
File Name : IMG_2353.JPG
Directory : .
File Size : 3.6 MB
File Modification Date/Time : 2013:11:17 14:07:45+00:00
File Access Date/Time : 2014:12:21 09:02:31+00:00
File Inode Change Date/Time : 2013:11:21 14:36:02+00:00
File Permissions : rw-------
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : Canon
Camera Model Name : Canon PowerShot A630
Orientation : Horizontal (normal)
X Resolution : 180
Y Resolution : 180
Resolution Unit : inches
Modify Date : 2008:03:16 15:00:37
Y Cb Cr Positioning : Centered
Exposure Time : 1/8
F Number : 3.5
Exif Version : 0220
Date/Time Original : 2008:03:16 15:00:37
Create Date : 2008:03:16 15:00:37
Components Configuration : Y, Cb, Cr, -
Compressed Bits Per Pixel : 5
Shutter Speed Value : 1/8
Aperture Value : 3.5
Max Aperture Value : 3.5
Flash : Off, Did not fire
Focal Length : 17.3 mm
Macro Mode : Normal
Self Timer : Off
Quality : Superfine
Canon Flash Mode : Off
Continuous Drive : Single
Focus Mode : Single
Record Mode : JPEG
Canon Image Size : Large
Easy Mode : Manual
Digital Zoom : None
Contrast : Normal
Saturation : Normal
Sharpness : 0
Camera ISO : 200
Metering Mode : Evaluative
Focus Range : Auto
AF Point : Auto AF point selection
Canon Exposure Mode : Program AE
Lens Type : Unknown (-1)
Max Focal Length : 29.2 mm
Min Focal Length : 7.3 mm
Focal Units : 1000/mm
Max Aperture : 3.6
Min Aperture : 8
Flash Bits : (none)
Focus Continuous : Single
AE Setting : Normal AE
Zoom Source Width : 3264
Zoom Target Width : 3264
Spot Metering Mode : Center
Manual Flash Output : n/a
Focal Type : Zoom
Focal Plane X Size : 7.44 mm
Focal Plane Y Size : 5.59 mm
Auto ISO : 100
Base ISO : 200
Measured EV : 5.94
Target Aperture : 3.6
Target Exposure Time : 1/8
Exposure Compensation : -1/3
White Balance : Auto
Slow Shutter : Off
Shot Number In Continuous Burst : 0
Optical Zoom Code : 6
Flash Guide Number : 0
Flash Exposure Compensation : 0
Auto Exposure Bracketing : Off
AEB Bracket Value : 0
Control Mode : Camera Local Control
Focus Distance Upper : 2.51 m
Focus Distance Lower : 0 m
Bulb Duration : 0
Camera Type : Compact
Auto Rotate : None
ND Filter : Off
Self Timer 2 : 0
Flash Output : 0
Canon Image Type : IMG
owerShot A630 JPEG
Canon Firmware Version : Firmware Version 1.00
File Number : 100-2353
Owner Name :
ISO : 200
Rotation : 0
Camera Temperature : 20 C
Canon Model ID : PowerShot A630
AF Area Mode : Multi-point AF or AI AF
Num AF Points : 9
Valid AF Points : 9
Canon Image Width : 3264
Canon Image Height : 2448
AF Image Width : 1088
AF Image Height : 409
AF Area Widths : 196 196 196 196 196 196 196 196 196
AF Area Heights : 74 74 74 74 74 74 74 74 74
AF Area X Positions : -196 0 196 -196 0 196 -196 0 196
AF Area Y Positions : -75 -75 -75 0 0 0 75 75 75
AF Points In Focus : 4,6,7
Primary AF Point : 4
Thumbnail Image Valid Area : 0 0 0 0
Date Stamp Mode : Off
My Color Mode : Off
Firmware Revision : 1.00 rev 3.00
Categories : (none)
Image Unique ID : 32b5b875f0cdc48bf17cc5a35bea5d12
User Comment :
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 3264
Exif Image Height : 2448
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Related Image Width : 3264
Related Image Height : 2448
Focal Plane X Resolution : 11412.58741
Focal Plane Y Resolution : 11439.25234
Focal Plane Resolution Unit : inches
Sensing Method : One-chip color area
File Source : Digital Camera
Custom Rendered : Normal
Exposure Mode : Manual
Digital Zoom Ratio : 1
Scene Capture Type : Standard
Compression : JPEG (old-style)
Thumbnail Offset : 5120
Thumbnail Length : 5344
Image Width : 3264
Image Height : 2448
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 3.5
Drive Mode : Single-frame Shooting
Image Size : 3264x2448
Lens : 7.3 - 29.2 mm
Lens ID : Unknown 7-29mm
Scale Factor To 35 mm Equivalent: 4.6
Shooting Mode : Program AE
Shutter Speed : 1/8
Thumbnail Image : (Binary data 5344 bytes, use -b option to extract)
Circle Of Confusion : 0.006 mm
Field Of View : 25.2 deg
Focal Length : 17.3 mm (35 mm equivalent: 80.6 mm)
Hyperfocal Distance : 13.30 m
Lens : 7.3 - 29.2 mm (35 mm equivalent: 33.9 - 135.8 mm)
Light Value : 5.6
BugBear
