RogerS":c8h9xhaf said:
the one thing that sticks out to my mind is that the way of working with a combi affects the relative benefit of some of these options. I think now that the fine-adjustment fence is essential on the spindle (as is the DRO). The fence is accurately located by two large pins. So if part way through some work, you need to do some more ripping then the fence has to be removed. These pins mean that when it is put back to carry on moulding, then your settings will be still there. Ditto the DRO on the spindle. You have to wind it down out of the way to rip, but after ripping, just wind it back up to the correct setting.
That's a very astute point.
I have the adjustable fence option on the Felder CF741 Combi (I think from memory it comes as standard) and you're right, you can indeed remove and subsequently replace the fence and yet retain accuracy to within 0.1mm.
I don't have the power raise and fall on the spindle shaft but I do have the "dial wheel" on the manual rise and fall handle, and that too genuinely works to the same 0.1mm accuracy as the digital set up and can also be zeroed. In practise I've found that larger tooling (such as tenoning set ups) often has to be removed in order to sink the cutter heads below the table surface, and at that point it all gets a bit much to remember every variable in order to return to previous settings.
Some workshops have machines with removable spindles (that's a standard feature on the CF741, I don't know about the C3), and they'll keep certain tooling on a dedicated spindle and then change the entire assembly for frequently used set ups. However, for the smaller workshops that are likely to buy combi machines in the first place, that's far too expensive given the sky-high cost of tooling.
I guess it all comes down to what you're actually making. For the bespoke or short run hardwood furniture that I make it's not that important to attempt to return
precisely to previous settings, you just run a bit extra on certain components to give yourself a safety net. I imagine it's the practicalities of bespoke furniture making that also influences Peter Sefton's views. However, for say a joinery workshop, where certain mouldings would be in regular production, being able to replicate those profiles exactly might be an important consideration.
One final point building on Peter's comments, I use the three wheel Felder power feed, and the tiltable power feed support is certainly beefy enough to allow running that either against the spindle table or against the spindle fence.
Here's a photo of my machine set up for spindle work with the power feed, you can just see part of the tilting support poking out behind the fence.
