Hi, I've applied three coats of Liberon Finishing Oil to a large coffee table, brushed on and left for 10 minutes, then wiped off with a cloth. I plan on applying another two coats at least, but I would like to end up with a gloss finish if possible. What is the best/easiest way to achiev this?
Should I finish the five coats then wet sand and finish with one final coat? I have some 3M 2000 grit laying around, a buffing machine, and some Farecla G3 compound although I'm not sure if it's any good for oil finishes?
V
V
