Hi,
I've just started wood turning and have been playing around with some logs I had lying around for the woodburner.
I made a bowl blank from a piece of oak (air dried for two years?). After I'd cleaned it up with a roughing gouge I thought I'd try to use a skew chisel to do some basic shaping. I had already played around with a skew on a softwood (pine) spindle and thought I was getting the hang of it - when I was getting catches I could just about understand what I'd done wrong.
But the oak was another story. After rounding, even though I had a smooth surface with the grain, the surface was very rough in the areas against the grain. When I tried to use the skew, however careful I was to slowly come off the bevel and start cutting, after a few turns of the blank I would invariably catch in the rough grain big-time!
Appreciate any clues as to what I might be doing wrong please?
Thanks, Colin
P.S. I should say that all my 'firewood' now gets looked at first as a woodturning project and only if it fails that is it still firewood
Thanks, Colin
