TheTiddles
Right, this has taken a couple more weeks that I thought it should but I'm mostly pleased with the results. The top is laminated iroko (from the benches in Corby) and is 2.5" thick, the aprons and caps are 2x6" beech, although the top is only 26x49" if I sit on the end overhang it doesn't tip up, which is impressive as I'm not small, it's right on the cusp of what I can lift, the legs are laminated again and draw-doweled together, I had never used this technique and I was suprised just how much draw you can get on them, I was offsetting the holes by as much as 5mm. The hardware is York from Axminster, which I am very impressed with for the money, the independent screws on the tail vise allow about 10 degrees of skew in the vise should I need it.
The three strecher design is so that I can build a 'Philly Stlye' tool cabinet to sit under the bench, the middle of the legs is the best place for the strecher but it just wastes so much valuable storage space, I haven't yet bolted the top to the legs, I'm not entirely convinced I need to either.
The only thing I'm not happy with is the vice handles, they just haven't worked out, they will get replaced at some point in the future
Aidan
Aidan
