I had a difficult glue up where I just did not have enough thickness of veneer to sand completely smooth, so i tried to buy some gorilla glue which apparently expands into joints.
Nope, no luck on that.
I found a tube of Evo Stik polyurethane wood glue (same tube as silicone, needs a gun to apply)
The label says and I quote " gap filling" and "dries clear". So it was worth a try.
I suppose 1 out of 2 isnt bad.
Certainly filled the gaps in the uneven surface, but the out squeezing once dry was like white construction foam.
What a clean up mess!
On the subject of silicone guns, has anyone ever come up with a way to stop the tube hardening off? Those screw on caps have never worked for me
