No skills":1vbnr24g said:fair point, perhaps the addition of 'approximate size' should be used when advertising items?? is there a defined standard that would cover a product like this? (like the british standard used for squares/squareness?)
Phew common sense!clk230":3s7ysq53 said:No skills":3s7ysq53 said:fair point, perhaps the addition of 'approximate size' should be used when advertising items?? is there a defined standard that would cover a product like this? (like the british standard used for squares/squareness?)
yes there is a defined standard its called weights and measures and is policed by the trading standards office , they can make you remove the items for sale until they are happy that they meet their requirements.They will allow a small tollerence but if its measuring 5.2mm not 6mm they will insist it is re marked as 5mm.
All seems fair to me its there to help and protect us.
matthewwh":12xbijci said:Hi Marc,
There should be a very slight taper in the width of the blades from front to back so you will get different width measurements at different points up the blade. Its barely noticeable, maybe half a mm to a mm over the entire length, but with that and the slight taper on the sides it's enough to prevent them from behaving like a nail and sticking in the timber.
Jacob":1bjlwa60 said:And I'm happy to explain - you have picked up some bad habits!bugbear":1bjlwa60 said:....
Yebbut, you set the mortise gauge to the mortise chisel; thus the mortise is automatically the right size, made in a single pass of cuts, and you were going to have to cut the tenon in two separate line anyway, so there's no extra effort. Works for me, but if you have counter examples, I'm happy to listen.
If you are doing a lot of stuff, say 5 windows with glazing bars, you could have something like 100 or so M&Ts to cut. You set your gauge to 1/2" and mark all your mortices and all your tenons. You can then put the gauge away. You then cut all your mortices with a 1/2" chisel, and all your tenons to the lines you have made. That's all there is to it.
If you have an odd sized chisel and set the gauge accordingly the M&Ts will fit but other details may be out of line.
Or if you swap odd sized chisel halfway through you may hit problems.
:lol: :lol:bugbear":v42hiiy7 said:...Er. Yes. That's the method I use too....
For one yes, for one hundred, not bloody likely!Racers":1hd3yoxh said:I see you can only make a mortice the same width as the chisel, you can't pair the sides slightly wider.
Racers":3ihzftzn said:Jacob
I would reply but you are wearing me out, I will just go along with every thing you say, you are right, you are right, your are right....
My heart sinks when I see a reply from you.
