Moxon Vice Jaw Lining
memzey
8 Apr 2013
St. Albans
I stuck some leather I scavenged off of an old sofa on mine, furry side out. Seems to work well.
colinc
30 Nov 2003
South Derbyshire, UK
2nd attempt at replying.....
I recently bought some Benchcrafted vice hardware which came with linings described somewhere as 'crubber'.
It seems to be a nitrile bonded cork and rubber composite gasket material and is available from many sources.
Here's a link to one on ebay: https://ebay.us/3VOIco
I have always used softwood jaws before so too early to say how good this is, but Benchcrafted do seem to know their stuff and if they use it you should be ok.
regards
Colin
marcros
11 Feb 2011
Leeds
I presume that you are talking a woodworking vice here rather than a metalworking vice?
cork times used to be plentiful, but I haven't seen them for a while. suede, leather or cork would all do, with preference to what you have available most easily.
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
Anything leather leaving the house is stripped of useful material. Old belts for clamp head covers, an old briefcase yielded good heavy leather for vice jaws, etc.
Fitz.
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
I don't see why you'd want to line your vice with anything unless you were working on really delicate parts. I've used bare birch plywood faces for years and I've never had a problem with them. I suspect you would also lose quite a bit of holding power if you lined them with something like leather, plywood gives a very positive hold.
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Mine are plywood, but the rear jaw is proud of the bench front. This does have some disadvantages, but the big advantage, and it's why I did it, is that I can slip over auxilliary vice cheeks. I have a pair lined with carpet, for example. I also have an excellent mortice jig that fits over, too (but I don't use it as I have an even more excellenter mortising jig, yet to be published).
However you arrange it, I do recommend the ability to fit auxilliary jaws.
Lonsdale73
21 Feb 2015
County Durham
Not wishing to sound pedantic but having google come back with flight times and a link to an Irish newspaper I was wondering if that was meant to say Cork tiles?
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
I think you'll find that there is a strong tradition of using foreign, thicker, papers as softening in gripping scenarios, but that their efficacy deteriorates rapidly, hence the need for speedily expedited copies.
Lonsdale73
21 Feb 2015
County Durham
Steady, the PC brigade might think you're calling the Irish thick!
Bodgers
21 Dec 2014
North Yorks
The Nitrile Cork sheet is commonly available (I think someone mentioned it earlier). I have it in my vice and I really like it. It seems very resistant to abuse and is grippy.
Sent from my P027 using Tapatalk
