Hi All
I want to make my first solid wood project and am going to start with
a picture or mirror frame with hand cut mitres.
I was thinking of making a mitre shooting board to use for this - Is there is an upper limit in thickness which you can shoot before the plane losses momentum and you need to move to free-hand planing?
I have a no.5 plane which I could try to shoot with and a low angle block plane which I thought I could use if I needed to free hand plane the mitres.
Is there a standard technique for adjusting the angle of the mitre if you free hand plane and find there are gaps in the joint (I know that with the shooting board you can add pieces of card or paper to adjust the angle as required) Or do you simply note the errors and adjust these local areas and retry the fit?
thanks
Andy
thanks
Andy
