A few days ago decided that I had had enough of creaking flooring in upstairs bedrooms. As the first bedroom was due to be re decorated and have new carpet I took the opportunity to fix the chipboard flooring using Spax screws leaving the existing nails in place.
In spite of using one of these
This happened (apparent only today). I had managed to screw the pipe securely to the joist :evil: The black tape is my temporary repair. It was the only thing I could find at Homebase at just after 5pm
This could have layed undiscovered for ages - the leak actually ran between wall cavity
At the end of the day this accident was due to my carelessness in not checking more thoroughly, however isn't cutting a notch to run pipes and cables bad practice - surely it weakens the joist and runs the risk of pipe being punctured
I am sure that I used the "Tracker" over all intended screw areas. It should have identified the pipes particularly as they actually lie slightly above the joists (the chipboard floor must have pushed them down.
I think I should replace the tracker with something a little better to identify wiring and pipework as I am intending to do the whole upstairs area. Anyone have any suggestions (without breaking the bank)?
Tony
Tony
