frugal
After talking to Phiily about how he cuts out the sides of his infil planes with a milling machine I got to thinking: Really when you get down to it, what is the difference between a router, a pillar drill and a milling machine?
As far as I can tell they all hold a spinny thing vertically and apply it to metal.
If you made up a sliding table for a pillar drill is there any reason why you could not put a milling cutter in the chuck and use it as a simple milling machine? It would not be as accurate as a milling machine (people seem to buy milling machines to do woodwork as they are more accurate, Robert Ingham specifically).
Likewise, if you got a milling cutter with an 8mm shaft, is there any good reason why you could not use it in a router on a slow speed? Attach the metal to a sub-base of MDF so that you were not cutting into the workbench and had a large enough piece of MDF to clamp the sub base down. I can see this one being messy with cutting steel as it would need coolant, but cutting brass does not need a constant feed of coolant.
I am sure that it is a stupid idea, but I am not quite sure why...
