Milling ash logs
Rob D
16 Nov 2018
Wotton Under Edge
Evening all
Although I have milled ash logs using a chainsaw mill previously I am far from an expert.
I have cross cut these sections to length and sealed them ready for cutting into planks but as you can see they’ve developed some mighty cracks, bigger than I’ve experienced previously.
Can anybody tell me if they think this would still be ok for milling into planks?
As above, most will develop some cracks, but it might not go far into the wood. Mill with the crack ( parallel ) and see what youve got
I would agree - cracks at the end form very quickly and rarely go too far in. What length are your logs?
I have done the same thing and found it cracked anyway. (Though the cracks didn't go far from the ends, and I got plenty of useable wood)
I wonder if PVA or the proper stuff is any better
With the price of timber you can’t not afford to process, this is milled ash and beech I’ve had done, even the shelving with timber on is taken out of the cover boards (first cut) chainsaw planked so the first cut was about a 3 inch cut, processed the first cut on the bandsaw to produce as much stock as possible
