Machining Aluminium with end mills.
Benchwayze
10 Mar 2007
West Muddylands
Hi folks.
I want to make a false top for my bandsaw out of 10mm aluminium sheet.
I shall need to machine a channel for the mitre guide, of 1/2" width x 3/16" depth.
I have a suitable end mill that I can put in my half-inch router.
What I need is the safe working speed to cut this channel in the aluminium.
Thanks in anticipation.
John :D
You will get a more accurate slot with a 2-flute slot drill rather than an end mill which tend to cut oversize in this situation. Failing that use a smaller cutter and work upto the width.
It will also clear the chips better at higher revs
Thanks folks. I am much obliged. I've noted all suggestions/advice, and I will take it from there.
If things get a bit 'leary', then I could finish up using MDF and Tufnol!
Thanks again.
John :D
