lubrication
sue denim
8 Apr 2011
South west France
Hello
I recently purchased a large planer thicknesser. I am looking at the lubrication of the feed roller bearings. They are a small 8mm brass hex head with a small ball bearing in the centre. Is this an oil can job or is there a different method that I am not aware of ?
Thanks in advance
'Sue'
If it has a ball bearing in the centre it maybe isn't a grease nipple. Use an oil can with a suitable sized nozzle. 3 in 1 oil is probably too thin - something a bit thicker like engine oil, lawnmower oil eg sae 30 or 10/40 grade.
I didn't know that.
I always thought a grease nipple had a ball bearing to stop the grease pushing back out. Like this:
    26.6 KB
    48.3 KB
looking at the manual it asks for a weekly dose of exepa mo2 or brs2 . This may indicate if it's an oil or grease nipple ?
'Sue'
'Sue'
MO2 is lithium grease Sue, I have some in my garage. I don't know what brs2 is but suspect it's similar.
Bob
Hi
MO2 and BR2, (note I don't know of BRS2), are both Extreme Pressure Lithium greases with molybdenum disulphide, (MoS2), as an additive - they will be dark grey in colour, (from the molybdenum), normal Lithium grease is usually a light brown.
From your description it sounds like you have a standard grease nipple which is charged with this:
It needs to be fitted with one of these - it should come supplied that way
If you're buying a grease gun as per above it would be best to get one with a flexible hose rather than the rigid pipe as shown in the photo above.
Regards Mick
    64.6 KB
    31.7 KB
