If you're determined to try them Harry for better or worse I'll tell of my experience.
Unfortunately this last couple of years I seem to have been making nothing but bloody great doors, wardrobes, kitchens, you get the picture?
Prior to that it was boxes, clocks and small items and I used lock mitres a lot. For such things as boxes and small draws they produce a beautiful clean mitred corner, but I found that the conventional router table was less than ideal.
The conventional router table has two problems with lock mitres,
one, you need a tall fence when cutting one half of the joint.
two, as the last cut is being made controlling the timber is very difficult as it is passing the cutter balanced on a knife edge!
I have found two ways around these problems,
one, I made a small vice mounted router table which could be turned so that the timber was always running horizontally.
Two, I inserted an alloy lined slot in to each 'fence' and used a sled, this removed the difficulty of balancing the timber on a knife edge at the last cut.
Unfortunately I can show no pics as the 'cheapo' router eventually burnt out and I dumped the lot with the intention of a MK11 to follow.
I also made a depth micrometer from a damaged Mic so the the cuts could be done in stages.
It also pays to make the timber wider than the final size as a means of removing any 'break out.'
Hope this helps, sounds a lot of work but if you are into boxes etc it's well worth the effort for the finished result.
Roy.
