Hiya,
Laserply has less inclusions in the mid section, many plys are filled with various fillers to cover inclusions in the cores.Lasers don't like cutting the filler that is used
B&Q ply and MDF contains various hazardous materials that can both damage the machine, the extractor and the operator.
To remove the staining from laser cut ply you need air....LOTS of air , it reduces carbon build up and keeps the cut line clean. Lasers are great but don't let anybody kid you into believing they can cut very thick materials, they can't. For anything over 12mm ply (good laser ply) you need a router not a laser.
Based on experience of cutting lasers between 50 watts and 7.5K watts.
Good choice going with HPC, Chris Jacobs is a very clever chap and knows more about the machines than pretty much any UK vendor (I don't work for HPC but have owned a few of their machines)
I would be interested if any other 3020 owners have found a supplier of ply that cuts well, preferably in London area.
Hindleys, Hobarts, Jennor Timber, DHH Timber, HPC Lasers, Avon Plywoods are some of the best (read: most economic) and all supply quality sheet.
as not all 3mm laser ply is exactly 3mm apparently
3mm laser ply can vary between 2.7mm and 3.5mm, MDF is very stable and 3.2mm MDF will only usually vary by 0.05mm +/-, the worst is Cast Acrylic, that varies by +/- 10% + 0.4mm so a 3mm sheet can be between 2.4mm and 3.6mm. Extruded acrylic varies by roughly +/- 0.1mm in general.
Just don't try cutting any PVC's, they liberate toxic chlorine gas
hope that helps a bit
best wishes
Dave
