Large holes
marcros
11 Feb 2011
Leeds
I am looking at outsourcing some work, but before doing so would like to understand the likely process. The background is a batch production of 20 units, each unit having a hole in each end.
Material would be mild steel bar, 1/2" X 2 1/2".
How would a 2" hole be put into the bar? Is it as simple as a holesaw?
Rorschach
Guest
6 Jan 2016
Devon
How accurate do they need to be?
A decent drill press will put a (good quality) 2" holesaw through that size of bar, it will be slow though, it also will not be super accurate.
You could get it CNC plasma cut at that thickness, probably tighter accuracy than the holesaw.
Best accuracy would be to have it plasma cut undersize and then bored out on a milling machine.
TFrench
6 Jul 2015
Leics
How far in from the end is the hole? Room to get a V-block either side of it I assume? If I was doing it I think I'd do them slightly undersize on the radial arm drill then bore to size in the mill if they need to be super accurate. If I had the big mill running I'd do it all in that. I recently got some U-drills in a job lot I can't wait to have a go with - not sure if they go as big as 50mm though.
Edit - could also be a perfect job for a 50mm annular (rotabroach) cutter.
marcros
11 Feb 2011
Leeds
thanks everybody. good to get some options, before I get a price for fabrication of the parts.
sunnybob
wysiwyg
11 Oct 2014
cyprus
I would seriously consider using tubing, and just block one end with a screwed or welded plug
marcros
11 Feb 2011
Leeds
the holes in tubes are in the wrong axis
CHJ
31 Dec 2004
Cotswolds UK
If the project requires the strength/stiffness of a 1/2" X 2 1/2", I query the advisability in cutting a 2" hole in the ends, there is only going to be 1/4" land each side which is a relatively weak point if any tension or bending loads are present.
On a small batch like that in an old style machine shop I would have used a vertical mill, drilled/endmilled and boring head to finish if size critcal.
If the holes are just for welding to 2" tubing the critical dimensions are not required (no boring head) and side wall becomes irrelevant.
CHJ
31 Dec 2004
Cotswolds UK
I can't be the only person reading that as a two and a half inch length of half inch bar, can I? :? :D
With a 2" hole in each end??
marcros
11 Feb 2011
Leeds
this is what we are looking at having made https://www.fishleighandsonshop.co.uk/t ... -432-p.asp
but the ball ends that we need are in a virtually unobtainable size, and are only available as a part like https://www.agrilineproducts.com/parts- ... cat-1.html
the bar size is an estimate at the moment, pending getting some full measurements. it is a paperwork exercise to see whether it would be viable. There is a small demand for the parts, because originals are few and far between and there are no reproductions available at the moment. The tractors date from the 50's to early 60's, so mass manufacture is never going to be worthwhile.
CHJ
31 Dec 2004
Cotswolds UK
Are you sure that the originals are just 'Mild Steel'.
I've modified and repaired several 'linkage' components in a hurry to keep harvesting going to finish a task and some were certainly a much higher spec steel.
marcros
11 Feb 2011
Leeds
no, that was just a guess, more as background to the holes. they are on a garden tractor rather than anything lifting tonnes of weight, but it needs some more research.
nev
21 Jan 2011
The green and wetter end of the M4.
I'd suggest that the link arms are not a flat bar with holes in, rather a flat bar with the ball ends (or ball end holders welded on the ends) . given that the ball ends would have to welded into the holes anyway as if they were pressed into the two inch hole, as mentioned earlier, you have the entire load resting on the remaining quarter inch.
so your shopping list would then be flat bar at x length , 2 to 3 inch sections of flat bar with one side chamfered at an angle and the other side 2" concave to accept ball end units.
Of course I could be completely off the mark :)
CHJ
31 Dec 2004
Cotswolds UK
Basically the difference between the original forged/welded? 'Fergy' links and the Fordson ? welded retaining plate copy.
Or is my memory too far out, it's a long while since I struggled to lift gear into place on those link arms, I always seemed to be just at few inches out of alignment when trying to hitch them up.
sunnybob
wysiwyg
11 Oct 2014
cyprus
The original sizes posted were why suggested tube. Something is wrong on that post, but the picture and explanation completely rules out mild steel in any shape or form.
There has to be another track rod end that would be longer, then it would just be a case of cut and shut. Or shorter, and just an extension welded in. At the cut stage the ball end orientation could be moved to fit the new application.
marcros
11 Feb 2011
Leeds
Pete, that was the first thought, but I cannot find any in cat 0 size.
