I haven't had much time this week to do much with the router table cabinet, I was hoping by now to have at least a couple of coats of primer on the cabinet with the final coats over the weekend. But I've been unsure which way to go with the dust extraction. I had a little play connecting the vacuum to the Triton whilst it was in the cabinet to see how much waste it would pick up [no connection to the fence] and it was quite good. I used a straight cutter and made several rebates in some 3/4" ply, as the leading edge of the ply moved closer to the edge of the table, waste was being sucked in to the rebate, just like it did in Mr.Maskerys video after he makes a large hole in the router plate.
So with a couple of ideas I called in to Axminster [Warrington] this morning, I could have ordered on line but wanted to see all the connectors and how they would fit together. I picked up a "T" Junction and a Blast Gate, which was the only thing the "T" Junction would connect to for securing to the cabinet. They all fit together perfectly and even though the Black Gate could be screwed to the cabinet, fitting a plastic collar on the inside gives a very secure hold. My problem here is getting 63mm hose to connect to the housing on the Triton router, or getting a length of vacuum hose to connect the router housing to the plast collar. I'm thinking with this method that I can remove the vacuum hose from the router and hoover up any waste that makes it in to the cabinet.
The T Junction and Blast gate have been superimposed in the above image, in the below image, I cut a 64mm hole in some 3/4" ply.
My other option and probably the one I'll go with is the Axminster dust extraction adaptor, sadly they were out of stock of 63mm hose but I found this on Amazon which I'll order over the weekend.
http://www.amazon.co.uk/63mm-Flexible-D ... cting+hose
I'm tempted to put the blast gate on the back of the fence, again it all fits perfectly, and for times when the fence is too far away from the cutter to have an effect, I can close suction to the fence off. I tried it directly above the adaptor but I'd have to cut quite a bit off the bottom of the blast gate to make it fit.
At the moment I haven't cut any holes in the cabinet, so any ideas/comments would be appreciated
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As soon as the hose arrives I'll be cracking on
I should have mentioned: If I go with the "T" Junction, I'll be connecting to the shop vacuum, and connectiong the chip extractor if I go with the extraction adaptor.
