kity k5 replacement motor
pils
15 Mar 2016
oxfordshire
Hello
the 1.1 kw 1.5 HP - SINGLE PHASE ELECTRIC MOTOR 240 V 3000 RPM motor on my kity combi no longer has torque. It's turning but even firm hand pressure on the spindle prevents it from spinning.
Therefore, I believe, I may need a new one.
Any bright ideas are most welcome. (besides cleaning all the sawdust off :)
When my K5 motor died ( 20 years ago now, so things may have changed) I found it much cheaper to have the existing motor rewound than to buy a replacement. Only downside is that they resprayed it navy blue whilst they were at it and it stuck out like a sore thumb!
Thanks again. There was, I confess, a hidden emphasis on "know" which I should have made transparent.
I've just had a very helpful reply from this chap robsonandfrancisrewinds.co.uk:
it may be as simple as a capacitor fault...
only going to cost you around than £20 with carriage for a new capacitor
and even if it does need rewinding you would need to replace the capacitors anyway..
so I took a look see and two wires have perished and are touching...so there is hope.
If you can identify the capacitor you would be able to get a replacement from Maplins
Have failed to do anything as have been helping the mrs. look after her mum. will update this post/you all, hopefully, in Feb.
kindest to all
Pils
