I hadn't updated this for a while but there has been progress! The machine is all up and working fine now, i've just been doing some of the other bits to get it all finished. Otherwise i'm very happy with how it's all gone, the machine is good, sturdy and operates well. I do struggle a fair bit with snipe still and working out how I go about improving that (whether it be technique or whatever) is something I need to do. I get probably 5cm of nearly 0.5mm on the tail end of each board.Looks great @sams93 - enjoying following this thread. Thinking about a 636 myself. What’s the latest?
Ive just purchased a 636 so would love the files too if possible please @sams93 ?Do you want the files, for some reason I can't upload the .stl files but I can email them.
There is also a set I found for the 635 which is just narrower.
will DMIve just purchased a 636 so would love the files too if possible please @sams93 ?
thanks. I've just been catching up on your build updates after I posted before. Great work man, I'll probably be copying you - I'm working out of a small workshop too. I'll be interested to hear about any design mods you'd make after you've had a chance to use your setup for a while. cheers nicwill DM
Yeah I will have to see how I get on with it after a few months of using. So far I realise that the unit is really quite heavy. I can manage to lift it in and out of the shed, but I have put a couple of extra supports under the shed floor so there is less flexing!thanks. I've just been catching up on your build updates after I posted before. Great work man, I'll probably be copying you - I'm working out of a small workshop too. I'll be interested to hear about any design mods you'd make after you've had a chance to use your setup for a while. cheers nic
@MikeK I just tried but it won't let me upload the .stl files as attachments.
The files are available on the internet though - I got them from here where they are available to download for free:
